Manual workstation - work assignments
I have two manual workstations and only one worker, I would like that worker follow the work sequence  assigned to him.
- does 2 MUs in the workstation (part 1), and goes to other workstation (part 2)
- does 2 MUs in the workstation (part 2), and goes to other workstation (part 1)
Someone have a example similar, and can  shared it with me?
Re: Manual workstation - work assignments
Hello Gabriela,
I have changed my example a little bit.
Look at the importer request control of the broker.
Steffen
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thanks, I resolved my problem!
Bangsow, can you help me?
My WorkerSequence_2 in process ST_20 (attachments) doesn't work correctly. I didn't finding the error in the simulation.
Hello Gabriela,
you need 2 parts from SingleProc4 for the assembly. So you need two times SingleProc4 in the sequence and a buffer between the SingleProc4 and assembly (so you can produce 2 parts).
The sequence for SingleProc doesnt work in this way. If the dismantlestation produces 30 parts, then you need the processing on singleProc only if the buffer9 is empty.
Best regards,
Steffen
Steffen Bangsow
web: www.bangsow.eu
.... I spent many hours trying to understand the real problem, thanks a lot.
my last question is (a bit stupid) but necessary ...
why the simulation stops after produced 704 MUs? I would like that it continues producing MUs.
the problem: your buffer calha_1 (ST_200) is full. So the sequence of the worker is blocked --> no parts arriving at buffer8 (ST_20).
Increase the capacity of calha_1...
Steffen Bangsow
web: www.bangsow.eu
