Method is running for more then 10s
Hello everyone,
is there an easy way to capture the potential trigger causing this endless loop?
regards.
Re: Method is running for more then 10s
When this dialog opens, you can press "Debugger" to open the debugger and pause method execution. You probably will find yourself within the method that causes this infinite (or very long running) loop.
You can use Print at different points in the method to pinpoint the specific line of code that is causing an issue.
Just remember to have the Console window open so that you can see the output of the Prints.
-Patrick
