Method responsible for attribute change
Hello dear community,
is there a way to find the method responsible for changing the user-defined attribute?
I have several methods in my model and i need to find out, which method changed the user-defined attribute in certain moment.
Many thanks for every kind of help.
BR
Re: Method responsible for attribute change
add an observer control to the object for the user defined attribute and write the command
debug
into the method
if there is a change in the value, the debugger window opens and you find the "caller" in the call chain
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Great advice, many thanks.
Thank you.
BR
