Method to search by name
Hello
I have in my model situation where I want specify the parameters based on the name.
if @.Name="Part_Nr_1" then
	.Models.Frame.PartRatio := .Models.Frame.Order[6,1];
But that is useless when I change position in the table. How can I search by name?
Like, find current "name" in the table then  find other parameters.
11 REPLIES 11
Re: Method to search by name
The easiest way is to activate ColumnIndex and RowIndex of your table.
There we go :
is
do
print .Models.Frame.Order["PartRadio","Part_Nr_1"] ; -- 1.5
end;
But if I want it to every parts, no only to Part_Nr_1?
I thinking about somethink like:
find @.Name in Table Order then
.Models.Frame.PartRatio := .Models.Frame.Order[...];
.Models.Frame.PartRatio := .Models.Frame.Order["PartRatio", @.Name] ;
The index allows to get directly to the cell without a loop or a find method.
I don't know why but it's not working.
it's ok when:
.Models.Frame.PartRatio := .Models.Frame.Order["PartRatio", 1 ];
but when:
PartRatio = 0 and @.Name = "Part_Nr_1"
You sure you've activated the row index ?
Becarefull if there is a space "Part_Nr_1 " like this.
Attach the model then I can have a look !
Much about this I have problem.
Okay got it !
You cannot activate the Row Index for this table so you can use this the find method.
Here we go !
is
do
	Order.CursorX := Order.GetColumnNo("Name"); -- starting position
	Order.CursorY := 1; -- set
	local index : integer := Order.find(@.Name) ;
end;
index contains the number of the row you interested in !
I don't know what I'm doing wrong but it is still bug,  and in the code has nothing obut "PartRatio"?
is
do
        .Models.Frame.PartRatio := .Models.Frame.Order["PartRatio", index ] ;
end;
