Method to select Excel File
I'm bashed because I cannot find a way to open an Excel File by method without using a path.
I'm looking for a method to execute the OPEN option in a Table file.
Not ReadExcelFile, openfile methods
Executed by Method.
Also tried with the filelink but same happened a path is required.
ActiveX is not an option due to my customer requirement.
I will appreciate your feedback,
cortega@interlatin.com.mx
+52 (81) 10801310
InterLatin S de RL de CV
Re: Method to select Excel File
look in the help for selectFileForOpen
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
