Model won't open after updating to a professional license from 30 day trial
I decided to try Siemens Plant Simulation software by signing up for a 30 day trial. Now the models that I created during that trial period won't open within the commercial software.
I have an error that reads:
This model/ object was created with a non-commercial license of the programme. You cannot use it in a commerial license.
Is there a way to convert the file so I can open and use it again?
Best,
Lucy
1 REPLY
Re: Model won't open after updating to a professional license from 30 day trial
As end user you cannot do this. The trial version is not intended for commercial use.
In this specific case I converted the model, so the issue has been resolved.
