Modeling rotating fixture
Hi Everyone,
I have scenario wherein i have to model a machine which has a rotating fixture. One of the fixture 's side is for loading and unloading the component(s) and other is where the operation happens.
I tried to model this machine using a track, two transporters and a singleproc.The challenge which i am facing is moving both the transporter at the same time maintaining same distance all the time replicating the actual scenario.
Has anyone tried modeling this scenario before?If yes pleas help out on this. I have attached the model with this post.
-Varun
Re: Modeling rotating fixture
Hi.
I can't open your model.
Anyway I made a small test for you.
It is just a concept, and you don't see the table turning (it is possible, but in my opinion doesn't worth the effort), but the logic sequence is correct.
I modeled my company's libraries with a similar concept.
Find a sample model attached.
uses Line and Container object
Thank you Alessio
Thanks S_J
