06-12-2018 05:21 PM - edited 06-12-2018 05:24 PM
I need to modify the summary report in order to see workers occupation without checking every worker. Can someone help me with that? I´m working with 13.2
Thanks in advance.
Solved! Go to Solution.
06-13-2018 06:22 AM
the summary report is generated by a Drain object at the end of simulation.
Worker are not considered. Please see in the index the corresponding item.
For the evaluation of Worker I recommend using the tool Workerchart.
Peter
06-13-2018 11:32 AM
Peter,
Thank you very much for your answer, I solved that problem.
