Modify assembly aspect in 3D
I'm creating a 3D model and I'd like to modify how the parts are assembled on a container. I modified how the parts look like and how the container looks like anyway I can't find a place where I can modify how the single parts look like on the container when they are assembled. My actual problem is that they float over the container.
Where can I get access to the modification of the parts location on the container?
Many thanks for your help!
Re: Modify assembly aspect in 3D
1. select the 3d pallet object
2. press cntrl 3
3. select mu animation tab
4. select individual location (#0#0...#x#y)
4.1 switch on location ( 3d arrow for better visibility of location position )
5. press edit button (on the right)
6. alter location position
