Move MUs to assembly station.
Hi all,
In my model MUs are not moving from subaassembly stations to main assembly station.
8 REPLIES 8
Re: Move MUs to assembly station.
The assembly stations doesn't work, because they cannot access all parts from the assembly list via connectors. If you place for each part type one buffer, it will work.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Ok thank you steffen.. can u post the model in version 11.
one more query. In Subassy1 parts A,B,C should assemble & in Subassy 2 Parts A,D,C should assemble & In Subassy 3 parts A,B,C,D should assemble..
Hi steffen the model is not working in 11 TR3. Please can you post the model in version 11TR3
your settings in the assembly stations are right, the assembly stations pulls the parts according to the assembly list from the predecessors
here is the model in V. 11 TR 3
Steffen Bangsow
web: www.bangsow.eu
Thank u steffen it's working.. I have one more query, i want to prioritize the parts, like i want part Type1 & type 2 to be assembled first. after the compltion of these parts only i want other parts to assembly.
I have used sorter (Buffer) to do the sorting. is this the correct way of prioritizing or is there any other ways to dom it.
The sorter is a good way to priorize. But you neet some stock in the sorter (to have something to sort). You can define your own attribute for sorting (you cannot sort by the name of the MU, it needs to be a number or time).
In your case it will not work. The preassembly starts, if all parts are available. If you priorize type1 and type2 this decelerates type3 and type4 and all preassemblies.
Steffen Bangsow
web: www.bangsow.eu
Thank you steffen.
