Move method does not work
Hi community,
As you can see in my frame "move" here, I intended to move all the MUs in the container to the Drain_parts, however, with my coding, it only does that once and then stops. I don't know how to make it continue until it is finished. Anybody please teach me. Thank you so much!
Re: Move method does not work
Hi Alano,
in the attached model for Plant Simulation 12.0 I added comments into the methods load and unload.
I changed the way of calling these methods.
Peter
Thank you Peter. But is there any way we can still mount 4 parts onto the pallet before it moves, and at the end it will move 4 parts to the Drain_parts?
Of course, it is possible.
But in the load method you must wait until the Source_parts of part created a part.
In the unload methode you must wait until the Drain_parts deleted the part.
Well this is getting more mind-provoking but intersting at the same time for me. Thank you for your instructions. I'll definitely spend more time on this!
