Moving a specific object from the buffer
I have a plant that creates 3 types of products. They enter a buffer, and when 4 of the same type are in the buffer, a batch of these products must go to the next process. I have a method that keeps track of how many of each type are in the buffer, but I can't figure out how I can move a specific type to the next process. I only know how to move the first object in the buffer.
Thanks in advance for your help
Re: Moving a specific object from the buffer
you can use the method <buffer>.mu(index) to access the parts in the buffer.
The destination should be able to receive a certain number of parts at the same time (e.g. ParallelProc).
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
How can I specify the type in index? When I use <buffer>.mu(1) it takes the first product in the buffer, and <buffer>.mu(type1) doesn't seem to work.
you pass an index (integer), you need to compare the type to find your MU e.g.
for i:=buffer.numMu downTo 1 loop
if buffer.MU(i).name =yourType then
buffer.MU(i).move(yourDestination)
end
next
Steffen Bangsow
web: www.bangsow.eu
