Moving parts with batch loop
Builder
Builder
Hello everyone
I am trying to write a method to move parts from store using a batch loop as follows.
for n:=1 to 2*.batchSize loop
for i:=1 to supermarket.Xdim loop
for j:=1 to supermarket.Ydim loop
if Supermarket.pe(i,j).cont /=void and Supermarket.pe(i,j).cont.name="Main_frame_red" then
Supermarket.pe(i,j).cont.move(.models.life_3.parts_finishing.main_frame);
.Models.LIFE_3.modules_stock[1,"main_frame_red"]:=.Models.LIFe_3.modules_stock[1,"Main_frame_red"]-1
exitloop;
end;
next;
next;
next;
here first loop (batch size loop)  describes the batch size, a global variable as Batch size (value 3).
second and third loops represents the x and y dimensions of the store(supermarket).
I wanted to move 6 parts with name "main_frame_red" by considering 2 times batch size, but it is moving too many parts.
Could anyone help me where i am doing wrong. is this program works as i intended or not.
Thank you
best regards
Re: Moving parts with batch loop
exitLoop terminates only one loop; try
exitLoop 2;
instead. This will terminate the two inner loops.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Builder
Builder
Thank you very much steffen
I tried and it some what helped me, but i am not getting enough parts to required destination.
Could you please have a look at my model.
I represent important objects with some colours in all the tabs.
 I call this method only once by "information flow" (method).
please ask me if anything is not clear
Thank you
best regards
sorry, but I cannot look into your method, because you are working with a non commercial license
Steffen Bangsow
web: www.bangsow.eu
