Multi portal Crane moveTopositionAbs
Hello everyone,
I have a problem with the crane 14.1.1
if i use the method moveToPositionAbs on a portal of a multiPortalCrane, I have an error message.
See attached model.
Can you please explain to me what i am doing wrong ?
4 REPLIES 4
Betreff: Multi portal Crane moveTopositionAbs
Hello rpinon,
the bug is already fixed, please use version 14.1.2 of library MultiportalCranes.
I attached the library.
Hope this helps.
GG
Hello rpinon,
you cannot move the hook up to 5 meter, because your portal has an height of 5 meter and you defined the height of the hook as 0.3 meter.
GG
Hello GG,
is the version 14.1.2 already released? I didn't find it in GTAC.
Best Regards
Leo
Version 14.1.2 of the crane library is included in maintenance pack 14.1.1 of Plant Simulation.
Ralf
