Name of column of highest value
Hi all,
I'm stuck with a simple problem.
I have values in a table and need to find the coulmn with the highest value in row 1.
With the max() function I can find the highest value. But what command can I use to show the name (or number) of the column, where the highest number was found.
Thank you very much for your help,
Ben
Re: Name of column of highest value
Hello Ben,
use cursorX and cursorY:
is
    row : integer;
    column : integer;
do
    tab.setcursor(1,1);
    tab.max({1,1}..{*,*});
    row := tab.cursorY;
    column := tab.cursorX;
end;
Thank you
