Re: Native attribute(s) of an Object
@simulator
You are absolutely correct, I read the helpfile wrong. Aplogies to all for any confusion I may have caused! Cat Embarassed
@JiriHloska  schrieb:
The command
SingleProc.isNameUnique("ProcTime") returns false.
So it does work, because FALSE means that the attribute exists (a slightly confusing method, granted ^^). You can then use getAttribute and/or getSubAttribute, to get e.g. the ProcTime distribution type.
Edit: Sorry, I created this 1hr ago and forgot to click on "Send"... Smiley Frustrated
___________________________________________________________
Alex Dilg, Consultant at SimPlan AG (www.SimPlan.de)
This post was good and/or helpful to you? Please provide some Kudos, thank you!
