Need to change the attributes of parallel Proc. at different times
Hello All,
I wonder if I can change the attributes of the parallel proc. so that it can have different dimensions at different times of the day and days of the week, or changing exit strategy of precessor so that it can sent parts to different parallel procs according to time of the day and day of the week.
Mohamed Elshal
Re: Need to change the attributes of parallel Proc. at different times
you can change the xDim and yDim attributes dynamically. One exception is, that you not can decrease the dimension, if there are parts on the places, you want to delete.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you for feedback,
I just need an example method to transfere Mus as an exit strategy to the following processes using TimeOfday and DayOf Week functions.  I wonder if you can help me with that example.
Thank you,
Mohamed Elshal
how does the exit strategy should look like?
Steffen Bangsow
web: www.bangsow.eu
I found your previous posts,
look in the exit control of the example
Steffen Bangsow
web: www.bangsow.eu
