06-15-2015 05:15 AM
Hi all,
for my study i have to understand a simple simulation model and make some changes to this model. The problem is that I don't seem to have all rights to make changes to this model that i got from my professor. I can't for example change the end time from the event controller. Is this a common problem and does anyone know how to fix this? I would appreciate it!
Albert
06-15-2015 05:20 AM
Hi Dalbertt,
this is probably because of the license you are using.
Either you are using a Viewer license which doesn't allow you to make any changes at all or you use a student license which doesn't allow any changes if you are above the limit of 80 objects.
So you should ask your professor if you can get an Educational license.
Ralf
