Number of transporters located on part of a track
Hi Guys,
I'm wondering whether it is possible to get the number of transporters located on a certain part of a track, e.g. the first 200 meters of a 1000 meter track?
William
Re: Number of transporters located on part of a track
Hi WilliamK,
you can use the following SimTalk code to get what you want:
is
do
	local contList := Track.contentsList;
	local count:integer;
	for local i := 1 to contList.ydim loop
		if contList[2, i] > 200 then
			count := count + 1;
		else
			exitLoop;
		end;
	next;
	print count;
end;
 But please keep in mind that the performance may suffer if you execute this very often.
Ralf
Ralf
Thank you!
