OEE Report
Hello All,
 i want to get OEE report of all resource but in one file.(Please check in image).. In plantsim, is there any function available to get OEE of all resource?
Thanks in advance
Re: OEE Report
OEE (https://en.wikipedia.org/wiki/Overall_equipment_effectiveness) is not a standard which is not that obvious in the given link, but clearly stated here (https://de.wikipedia.org/wiki/Gesamtanlageneffektivit%C3%A4t)
2018-08-30 11_16_16-Gesamtanlageneffektivität – Wikipedia.pngAccording to that it´s obvious that you have to specify in more detail what OEE means in your case.
Anyway, what ever it might be, each kind of information that is required to calculate OEE based on your demand will be available in Plant Simulation (usually availability and performance) or has to be introduced/collected by you (usually quality).
This way it´s hopefully becoming clear to anyone who is performing simulation tasks, why Plant Simulation doesn´t provide OEE by default ... it´s just impossible.
Always consider using the AttributeExplorer!
