OPCClassic and RSLinx Classic OPC Server: Looking for tag syntax for Item Name and AccessPath cells
1. What is the syntax for the Item Name in the Table below when connecting with an RSLinx Classic Rockwell OPC Server?
2. Is the AccessPath required? If yes, what is the syntax?
Thank you,
