OUT OF MEMORY
Sometimes when I try to add control structure into Method from menu tab Plant Simulation is crashing(not alsways) withe th error 'Out of Memory' . I checked the status of the Ram and see that tecnomatix is using more than 3 GB when this error occured. (Since server has only 4 GB)
Is this normal behaviour? Bug ? If it is not why it go crash suddenly?
Thank you for your feedback.
3 REPLIES 3
Re: OUT OF MEMORY
Hello Nzhtbk,
this is definetely not normal behavior. If you find a way to reproduce this issue we will be able to fix it.
Ralf
Betreff: OUT OF MEMORY
Siemens Legend Siemens Legend
Siemens Legend
thanks for reporting!
Could you please …
… specify the version of Plant Simulation you use,
… the method you try to insert a control structure and
… what control structure you try to insert
… before running into this "Out of Memory" crash?
Thanks in advance!
Best regards,
Martin
Martin Lemburg
Siemens PLM Software
Digital Factory Division
Product Lifecycle Management
Manufacturing Engineering Software / R&D / Plant Simulation
Siemens Industry Software GmbH, Berlin / Germany
Plant Simulation version 12
It is not occurs on spesific structure, but I can say that the last method I tried was 'inspect...when'
Method was empty.
But this problem not  only on control structres , sometimes suddenly without any pre process while I am working on..
Thank you !!
