Object data type disappears in tablefile
in my model, a method inserts the entity name in a tablefile.
When the entity leaves the model, the name in tablefile becomes (?)
Is there a way to tell the software to not do this, without converting the object in string?
Alessandro
Re: Object data type disappears in tablefile
It's normal. The column shows the MUs name so when the the MUs disparee because you delete it or if you reset your model, it shows a VOID.
You can change  your column format from object to string. (Select your column Click right -> Format -> string).
and When you fill your table convert the MU to a string thanks to " to_str()" .
Table[4,i] := to_str(@) ;
So the only way to do it is by transforming the object in dtring. Ok.
Thanks for tour answer
Not transforming the object but changing the format of the 4th column from "object" to "string".
