Open a Method/Dialog from HTML Report
Hello all.
I am currently trying to create a HTML report that reports on the status of multiple different frames and idealy provides links to different methods within the frames, got the report generating and got a path to the frames but am finding it hard to get the link to work.
From looking at the report produced by the Profiler I have had an attempt but it instead tries to open it in internet explorer and not within Plant Sim.
"<a href=\"opendialog:" + Method_Path + "\">" + Method_Path + "</a>"
Above is the HTML code that I have tied to get working, any tips or pointers towards a working solution to create a link to open the method.
Also is it possible to open a method at a set line of code either through SimTalk or from a HTML report?
JamesM
Re: Open a Method/Dialog from HTML Report
It looks like you are using too many "-signs. Can you check the resulting HTML-code as you generate it?
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Hello
The resulting line in the HTMLReport object looks like:
<a href="opendialog:.Test_Area.Frame.Run">.Test_Area.Frame.Run</a>
JamesM
Can you test without them?
Gert Nomden
For clarity, please test it as follows:
"<a href=opendialog:" + Method_Path + ">" + Method_Path + "</a>"
Gert Nomden
Hello
If I remove all of the " from it, then the same thing still happens, it shows the report and when I click on the link it tries to open it within Internet Explorer instead of with Plant Sim.
JamesM
Yes, I now noticed the same problem. Strange, because the code looks to be exactly the same format as in the Profiler-report!
Maybe the target for the link is defined elsewhere. Maybe one of the Siemens people can tell...
Gert Nomden
This will work:
<a href="opendialog:.Test_Area.Frame.Run" target="_self">.Test_Area.Frame.Run</a>
Ralf
Hello.
Thank you, this worked for me, just put it into my code and tested it.
JamesM
Yes, this works, with and without "-sign.
Good to know!
Gert Nomden
