Operation time for each part
Hello colleuges!
I'm a raw soldier in Plant Simulation, I can't find any information about my problem:
I need to make the workshop with 5 processes for 5 different parts and different operation times for them at the each station. I attach my file with all data,  but it doesn't work correctly.
Who knows, what should I change in my model?
Many thanks in advance!
Betreff: Operation time for each part
Hello Valery,
at the moment your model is not working because your SingleProc2 is using an importer for processing, but your broker has no services available for disposal, so the part on SingleProc2 cannot be processed:
Your Broker needs either an Exporter or a WorkerPool, if you want to import services for processing/setup at the SingleProcs.
Alex
___________________________________________________________
Alex Dilg, Consultant at SimPlan AG (www.SimPlan.de)
This post was good and/or helpful to you? Please provide some Kudos, thank you!
Thanks a lot!
