Order list of workers
Hello there,
I created little model where I want to control the worker, who is carrying parts from 6 Stations to the buffer. There are two priorities of the stations: Left ones have 1 and the right one have 2. Model works like this:
After the part is done on the station method is called, where depends on prio is written the station where is done the part and worker can takes the part away. If it is prio1 it goes at the end of list, otherwise to the top. After the worker takes the part from the station, he cuts the 1st row of table and should go to the station, but he is controled not by my cardfile but with the inner list which has been added to worker by Broker.
Is there any way to modify the inner orderlist?
If its not clear, I will try to explain it other way.
Thank you
Re: Order list of workers
you you want to control the destination of the carry part operation of the worker?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
