PNG file (Imagefile - Layout) Import in to 3D as a background
I have a layout in .PNG format so it is image file and i want this image file as a background in 3D model directly.
I am creating 3D model only.
Please help.
Nil_DME
4 REPLIES 4
Re: PNG file (Imagefile - Layout) Import in to 3D as a background
insert a textured plate into your frame (3D - Edit...), in the menu of the textured plate, you can select your layout file
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Inside the frame you want to place the png select the Edit-ribbon/Insert Shape/Textured Plate and select your image
Always consider using the AttributeExplorer!
Thank you so much, it works but image quality is not good.
I also set same PNG as a Background in 2D and its quality is very good. Colors are bright and other things easily visible.
Is there any other fine tunning can i do to make same effect in 3D from same PNG?
Nil
the quality of both depends on the:
  1. resolution of the png (2d and 3D)
  2. scaling factor (2D)
  3. size of the textured plate (3D)
in the example below I imported a dwg (from our training) to 2D, exported it as a png and used this on a textured plate in 3D, find the dwg and the spp attached
