PS v12.1 crash changing exit strategy in singleproc
I accidentally chose to remove the "Carry Part Away" attribute and change it to "Cyclic" in my SingleProc while the simulation was running, but paused. This casued Plant Simulation v12.1 to crash with the following error message (picture attached):
Posting this just in case the bug went unnoticed among the developers Smiley Happy
Edit: Opening the backup file saved yielded another crash (picture attached - Backup_Crash.png)
so i cannot open the backup file. Is there a way to salvage my model?
Re: PS v12.1 crash changing exit strategy in singleproc
Hello ET_Boys,
thanks for reporting this crash!
We will try to reproduce it.
Ralf
