Parallel Processing Problem
Hello All
I have a situation where in the worker loads two parts on to parallelproc1 from parallelproc and after every cycle ,the worker has to unload the two  parts simultaneously from parallelproc1 and place on the buffer1  and then load two new parts from parallelproc to parallelproc1.
I have the logic written but the model seem to be not working as per the scenario. I request anyone to look into the model and help me with it.
Kind Regards
Sujith
5 REPLIES 5
Betreff: Parallel Processing Problem
Hello Sujith,
On tab Exit of the ParallelProc you defined the target for the MUs as ParallelProc1. So every parts will be carried to this station.
Remove the target definition on tab Exit of the Parallelproc and define the target of the MU by setting attribute Destination of the MU.
Hope this will help.
GG
GG
Could you please send across the modified model as per the solution given
from your side. Because its not working,hope so i would have misunderstood.
It would be of great help.
Sujith
Hi Sujith,
soory, but I didn't have the model running, I just recognized that the move statement in your entrance control disturbs the behavior of the worker when carying part away is used.
GG
GG
HI
The logic is not working, its behaving in a different manner
Hello Sujith,
attached you will find your model. The worker is carrying 2 Parts from ParallelProc to ParallelProc1 and afterwards 2 parts from PrallelProc1 to Buffer.
I removed all method call and only inserted to methods as you can see in the model.
Hope this will solve your problem.
GG
GG
