ParallelProc processing
Hello dear community,
is there a way to program the ParallelProc station to start processing when all positions are mounted with a MU?
Many thanks to every answer.
BR
3 REPLIES 3
Re: ParallelProc processing
Which version are you using ?
from PSi v14.1 onwards
you can switch this behaviour on or off (s.b.)
I got v13.
Unfortunately, ParallelProc does not have this option.
maybe it's easier (in Psi v13) to model this kind of
parallel proc behaviour through an assembly station
