Pause in shift calendar
Hi everyone.
I want to make a pause time every 1.5 days.
However, Shift calendar can only set the pause time within 24 hours.
How do I create this?
Betreff: Pause in shift calendar
Hi SubinChae,
you can start and end a pause using simtalk. First methodcall comes from init-method when simulations starts. Then call the method again every 1.5 days.
regards dst
simple++ / eM-Plant / Plant Simulation
Thank you dst
I'll try it.
The attached model for Plant Simulation 12.0 shows, how you can solve it without SimTalk. For this purpose there is the object Generator.
Thank you for your reply.
