Personnel Library other Bug
I found another bug in the Library Personnel library (see picture)
in context menu (click on "Satisfied stations")
Thank you,
Roman
Re: Personnel Library other Bug
Hello Roman,
please try the repair code
.ApplicationObjects.Personnel.Internal.Tools.createAttr("AOLlanguage","integer")
.ApplicationObjects.Personnel.Internal.Tools.AOLlanguage := 2
Then this error of the context menu will not happen.
Peter
Thank you for fast answer.
I do not know where to insert this code because the library is locked.
Thank you,
Roman
I'm put code .ApplicationObjects.Personnel.Internal.Tools.AOLlanguage := 2
to debug window and now is all OK
Thank you,
Roman
