Personnel Library
I've tried to implement a Personnel library for more complicated maintenance, but I can not assign the machine to the ServiceStation (see the attached image). I read in the Help that dragDrop eg. SingleProc to ServiceStation, but it does not work. Is there a little demonstration of how this library works?
Thank you
7 REPLIES 7
Re: Personnel Library
you should ask the creator of this library; the drag and drop control of the workplace is not implemented (empty method), but it replaces the default behavior of Plant Simulation (assignment of station). You need to edit in the method drag_drop of the ServiceStation.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you for the quick reply Steffen,
This is the Plant simulation library (in the "Deprecated" folder in the "Libraries" folder).
So this question is probably directed at the developer's plant simulation software.
Thank you
Roman
Betreff: Personnel Library
Hello RomanRak,
we are looking for a solution of this problem. As soon as we will have a new version of the library we wioll come back to you.
GG
GG
Ok, thank you,
Roman
There is something new about fixing this library?
Thank you,
Roman
Hello RomanRak,
we fixed the bug in the Personnel library. Can you please provide your mail adress, so we can send the library.
The new version of the library will also be available in next maintenance pack of Plant Simulation.
GG
GG
Helo, my contact email
Roman Rak
Offline Programmer & Software Developer
Dept.: BTCZ Technical Service
Rolling Stock Equipment (RoQ)
roman.rak@rail.bombardier.com
Bombardier Transportation Czech Republic a.s.
Svatopluka Čecha 1205
470 01 Česká Lípa, CZ
www.Bombadier.com
T: +420 487 802 457
[L_EoM_FR_BK_53x16mm]
Please consider the environment before you print / Merci de penser a l'environnement avant d'imprimer / Bitte denken Sie an die Umwelt bevor Sie drucken
Bombardier Transportation Czech Republic a. s., entity identification nr. 499 02 083, with registered office in Czech Republic, Česká Lípa, Svatopluka Čecha 1205/12, postal code (PSČ) 470 02, on record in Commercial Register kept by Regional Court in Ústí nad Labem, in section B, file nr. 496. Bombardier Transportation Czech Republic a. s. is a subsidiary of Bombardier holdings.
Bombardier Transportation Czech Republic a.s., IČO 499 02 083, se sídlem v České republice, Česká Lípa, Svatopluka Čecha 1205/12, PSČ 470 02, zapsána v obchodním rejstříku vedeném Krajským soudem v Ústí nad Labem, v oddíle B, vložce 496. Bombardier Tranbsportation Czech Republic a.s. je součástí koncernu Bombardier.
This e-mail message, and any attachments, may contain information that is confidential and/or privileged. They are intended for the exclusive use of the addressee.
Any other person is strictly prohibited from disclosure, distribution or reproduction. No waiver whatsoever is intended by sending this e-mail.
If you receive this e-mail in error please immediately inform the sender by return e-mail and delete this e-mail message along with all the attachments and destroy all copies.
