Photoeye Blocked/Clear
Has anyone modeled a photoeye block/clear with a timeout value.  For example, the photoeye is considered blocked when the photoeye has been blocked for x amount of time or the photoeye is considered cleared when the photoeye has been cleared for x amount of time?
Thanks for your input,
Brian
Re: Photoeye Blocked/Clear
have a look at
&method.methCall(delay)
and wait
you can use a sensor for blocking:= true
if you dont need more commands in this method. you can use wait for wait a certain time and then unblock your photoeye
or you use a separate method for unblock (methCall with delay)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
