Re: Pick and Place Robot Buffer Problem
here you are
Just add to your MBuffer method this line
RobotC.setdestination(@.destination,true);
and to your MTrackDE this line
@.move(RobotC)
After that your model should work.
Kind regards,
Igor
Thank you so much, this worked!
