Pick and Place
I have a production line with several stations. I want to determinate from wich station the Pick and Place gets the MU and where it drops. The sequence should be always the same. How can I do it?
Re: Pick and Place
the "basic direction" you set with the help of connectors
What kind of sequence you need?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: Pick and Place
I want the PickandPlace to get the MU from a Source, bring it to a SingleProc1, then get a MU from a SingleProc2 and bring it to a SingleProc3.
Re: Pick and Place
you can use the exit control of Source and SingleProc2 to "address" the MU. You can use the attribute destination to do this. Than you can use the exit strategy "MU attribute" of the PickAndPlace to select the right successor (see help).
Steffen Bangsow
web: www.bangsow.eu
