04-16-2018 07:43 AM
Hi, In my simulation, PickAndPlace robots move the entity between stations. I'm facing an issue in PickAndPlace robots animations. At some point of time, all the robots stop to rotate but entity are been transferred between allocated stations. I have ensured the attributes "NumAnimationEvents" of each robots to be more than atleast 1, still they aren't rotating to their destinations. Can anyone help me on this? Thanks in advance.
I use PlantSimulation v 12.0.4 and I have attached the videos of my simulation model also.
Solved! Go to Solution.
04-16-2018 08:11 AM
for robot animation the icon animation must be turned on. Perhaps you have turned it off?
Furthermore you should check the angles and the times table for correct values.
Kind regards
Karola
