Plant SImulation Storage crane 3D representation
Hello all,
We are to trying to visualise the parts storage in the storage crane during simulation. But the problem is that the stacking of the parts are not getting displayed properly i.e., stack height and the distance between the stacks are not proper. I also  like to add that, earlier we were working on Plant Simulation V11TR2 and then switched to Plant simulation v12.
Is there any solution for this?
Many thanks in advance
Re: Plant SImulation Storage crane 3D representation
Hello Animate,
have you upadated your Cranes library to the one from version 12?
And can you post a model which shows the problem?
Ralf
Hello Ralf,
Thank you for reply.It turned out that there was some problem in my model, i think that's why i was not able to see the 3D visual of storage crane properly. When i created the same thing in the new one it is working fine.
Thanks again
Animate
