Plant Sim Model extention
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
Hi All,
I wonder if it is possible to save the plant simulation model file in such an extention, that it can be viewed on a different PC without Plant Simulation software installed on it.
Irina
Re: Plant Sim Model extention
Hi Irina,
that's exactly what Pack&Go does.
Just select Pack&Go from the File menu, then you can package your model together with a runtime environment.
The created executable can be sent to someone else, who then can view and run the model in a viewer license.
Ralf
Ralf
