Plant Simulation Teamcenter integration Issue
Hi
I did setup entered Teamcenter server URL in connection tab. When I click Import button I am getting following error
Error as  " Object reference not set to an instance of an object". But if I try  tosave model in Teamcenter using the same Teamcenter server url, it is working fine.
Please suggest me to fix the issue.
Thanks in advance.
Sampath
Re: Plant Simulation Teamcenter integration Issue
Hi Sampath.
Which version of Plant Simulation and Teamcenter are you using?
Could you please show what you entered in the Connection tab? Especially the server URL.
