Plant Simulation Worldwide User Conference 2016
The user meeting registration page is up and running. An official invitation will follow but you can already register. If you are interested in presenting please send me a short note.
https://www.plm.automation.siemens.com/en_gb/campaigns/single_topic.cfm?Component=243749&ComponentTe...
Matthias Heinicke
Siemens Industry Software GmbH
A Digital Factory Business
Weissacher Str. 11
70499  Stuttgart, Germany
matthias.heinicke@siemens.com
Re: Plant Simulation Worldwide User Conference 2016
Hi Matthias,
Are the presentations from PSWUC2016 going to be published like in 2015: https://community.plm.automation.siemens.com/t5/Plant-Simulation-Forum/Plant-Simulation-2015-Worldwi...
Best regards,
SaMe
Hello SaMe,
yes, the presentations of the 2016 Plant Simulation user conference are uploaded under "Groups"
https://community.plm.automation.siemens.com/t5/Plant-Simulation-Worldwide-User/gp-p/Plant-Simulatio...
e.g. 03_Piepenbrock_Tecnomatix_Plant_Simulation_13_Release_Highlights_Final_07.pdf 04_Johannes_Stoldt_Fraunhofer_Institut_fuer_Werkzeugmaschinen_und_Umformtechnik_IWU_Vattenfall_Open-pit_Mining_Handout05.pdf 05_Ganninger_Procter_&_Gamble_From_product_design_to_layout_and_equipment_design_The_value_of_a_3_year_simulation_effort_for_plastic_stick_fabrication.pdf 06_Hermans_Designing_an_Overall_Equipment_Effectiveness_calculator_in_Plant_Simulation.pdf 07_Schneider_Eisenmann_Simulation_based_design_of_an_electrified_monorail_system_with_high_throughput_and_short_delivery_times.pdf 08_Pfaff_PPI_Informatik_KarisPro_autonomous_Intralogistics_Robots_AGVS_Industry4.0.pdf 09_Henry_ATG_The_Automated_Technology_Group_Ltd_Plant_Simulation_A_controls_partner’s_story.pdf 10_Stauber_Simplan_Handling_of_7_million_data_records_in_one_complex_Plant_Simulation_3D_model.pdf 13_Shoda_Mazda_Closed_loop_between_production_engineering_and_factory_by_Plant_Simulation.pdf 14_Zupan_University_of_Ljubljana_Defining_the_right_option_of_mixed_warehouse_type_for_final_products_through_simulation.pdf 15_Johannsen_EK_Standardized_simulation_of_complex_AGV_systems_at_EK_Automation.pdf 16_Bucci_SimTec_How_a_world_leader_in_melt_shop_building_uses_Plant_Simulation_Continuous_Casting_Machine_and_Transportation_Equipment.pdf 17_Davtyan_Comau_Automated_model_generation_of_production_lines_in_Plant_Simulation.pdf 18_Batija_Unity_Integration_of_material_flow_simulation_on_a_greenfield_factory_and_hospital_planning.pdf 19_Piepenbrock_Siemens_Hands_On_Workshop_Introduction_to_Plant_Simulation_Version_13.pdf 21_Nomden_cards_PLM_Solutions_B.V._Warehouse_simulation_made_fast_and_easy_with_WHL_4.6.pdf 22_Wohlfeld_Faro_Do_it_yourself_From_3D_LaserScan_to_application_summary_Workshop_Faro.pdf 23_Roosen_more3D_Connecting_Plant_Simulation_with_mobile_3D_&_Virtual_Reality_Systems_e.g._using_an_Oculus_Rift.pdf 24_38_Joos_Siemens_Introduction_to_SimTalk_2.0.pdf 25_Nomden_cards_PLM_Solutions_Introduction_to_SAPPHIRE_Simulating_tasks_with_complex_dependencies.pdf 27_Roesch_Komarek_Siemens_Create_Visually_Pleasing_and_Realistic_3D_Models.pdf 28_Bauknecht_Siemens_Database_interfaces_SQLite_ODBC_Plant_Simulation_Excel_bi_directional_data_exchange_data_transfer.pdf 29_Steinhauer_Flensburger_Schiffbau_Gesellschaft_STS_library_for_complex_assembly_and_logistics_new_version_10_1.pdf 30_Loraing_Siemens_Live_Demo_Configuration_of_the_Teamcenter_Plant_Simulation_interface.pdf 31_Komarek_Roesch_Siemens_SimTalk_for_3D.pdf 32_Lemburg_Siemens_Model_result_documentation_using_HTML_reports_fast_and_efficient.pdf 33_Stauber_SimPlan_Result_data_handling_Data_Export_via_SQLite_and_Access_Interface_plus_SimAssist_based_evaluation.pdf 35_Tobel_Mock_Siemens_Introducing_the_Worker_Freely_Moving_Within_the_Area.pdf 36_Schmidt_Siemens_A_short_introduction_to_embedded_optimization.pdf 37_Bauknecht_Siemens_Value_Stream_Mapping.pdf 39_Gross_Siemens_New_Electrical_Overhead_Monorail_Library_in_Plant_Simulation.pdf 39_Gross_Siemens_New_High Bay Warehouse_Library_in_Plant_Simulation.pdf
