Plant Simulation12.1 intrgration for Teamcenter10.1 Exception
I integrated Teamcenter10.1 an Plant Simulation12.1 and get an exception below:
I think if i integrated as a wrong way,because i have not any documents of integration.
My workflow:
1.Install Teamcenter10.1
2.Install Plant Simulation12.1
3.Deployed TC10 TEM Package in Teamcenter environment manager
If any body have solutions of my exception or have any documents of integration could share with me?
Thanks a lot!
Re: Plant Simulation12.1 intrgration for Teamcenter10.1 Exception
To those of us who don't understand the language in the error message, could you translate it for us?
Thanks for reminding me。
The Chinese can transfer as“You have not set the reference of object to the instance of object”
Please let me know how you solved this issue. I am also getting same error
Thanks in advance
Sampath
Hi Zhicheng and Sampath.
To the original poster Zhicheng: please specify the URL of the Teamcenter server in the Server edit box; it should be something like: 'http://machine_name:7001/tc'.
To Sampath: let's follow up on your question in your own post.
