Plant simulation 12 crashes upon opening an spp file from version 7
Hello PLM Community,
I am trying to open a model on my Laptop in version 12, originally created in version 7 at my university. Any file I try to open it shows me an error message and the program crashes.
An error snapshot and a sample file are as attached.
Any solutions would be greatly appreciated.
Re: Plant simulation 12 crashes upon opening an spp file from version 7
You are using version 12.0.3. The crash you encountered has already been fixed in newer versions. I can load the model into version 12.0.7.
Thanks a lot for quick reply!
That's great! How can I get that version?
I currently have an educational 30-day trial licence and I downloaded that.
I migrated your model to version 12 so that you can load it into version 12.0.3.
