Plant simulation gantt chart.
Can anyone tell me how to use the gantt chart with a simple model.
Re: Plant simulation gantt chart.
Example models (start page of the software), Small examples: Tools and Optimization>>Wizards>>Sankey and Gantt.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Thank you..
I haveone more query. Where can i find a small example of plant simulation shop library.
Hi ibrahim,
This is a license-controlled library. I have not seen example models of it.
Gert Nomden
Gert Nomden
Ok.. Where i can get the document of plant simulation shop library.
Here it is...
Gert Nomden
Thank you Nomden. Actually i wanted the tutorial of shop library. where can i get it.?
Better ask your local Siemens contact.
Gert Nomden
Thank you.
Siemens Legend Siemens Legend
Siemens Legend
Hello Ibrahim,
for a job shop simulation model most people just use a simple list of operations per part and a scheduler method, assigning/moving the part to a suitable station for the next step.
As scheduler rules in a project are typically very specific this simple approach proofed best in practice.
In this context you can easily use the Gantt charting tool to display e.g. activities per station and time.
Best regards,
gepi
