Re: PlantSim demo version and interface examples are not working?
The OPC DA Server 2.05a will implement the OPC DA 2.0 interfaces.
So, yes, the connection should be possible.
Ralf
Is there any limitation in free trial license other than "interface does not work"?
Hi abhik_giri,
the model size is limited to 1000 counted objects in the trial version.
Ralf
Ralf
