Power operator
I would like to assign a variable using the following equation, but this doesn't work.
var1:=var2^(1/30)
But apparently the power operator is not known in this form at PLM but I don't know how to perform this now and kind find this in the hep context
Re: Power operator
Hi Jappie_166,
You can write the following:
var1 := pow(var2, 1/30)
Ralf
