PowerPoint slides in 3D
Hi Community,
Ever wanted to have a PowerPoint slide set in your 3D model?
Just load the attached object in your model and start the method SlideImporter.
(Needs Plant Simulation 12 or newer.)
Ralf
Re: PowerPoint slides in 3D
I can't make it work. What are the sequence to make it run?
  1. Open a V12 or newer model with 3D
  2. Drag the SlideImporterV12.obj file into your class library
  3. Start the new method SlideImporter and follow the instructions
Ralf
Ok I get it!!! But this method only load the presentation, or does it also make the animation passing from one slide to other?
It only converts the presentation into textured plates.
Ralf
