Practice Plant Simulation 3D
If you are new in creating a 3D model in Plant Simulation this introduction course might help you. It is a step by step course for very first beginners. The complete training should not take longer than 20 minutes. It guides you through the generation of a 3D model , graphic exchange and the setting of positioning points for movable units in Plant Simulation 3D.
Re: Practice Plant Simulation 3D
Question refers to: 3D training model, (PDF file, 3D modeling in plant simulation step1 page 8). I tried to open singleProc from class lib. In 3D.  The result is empty window and I can t delete the original graphic. Note: I can see the singleProc object only in class Lib. of folder Material flow. So what is the way to replace the graphic of object with jt file?
First click on this icon:
Then you can select the old icon and delete it.
The jt-file you can drag from the windows-explorer into the 3D-window to include the graphic.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
