Priority in importer not working properly in my case
In my model, worker/operator moving first towards station to pickup the parts having lesser priority.
Re: Priority in importer not working properly in my case
I guess the lower prioritized  request / event
,to pick up the parts,  is (time wise) before
the higher prioritized request.
To get the desired sequence you should swap the
scheduled requests  e.g. block the lower prioritized  request
until the higher prioritized  request has been accomplished.
