Problem dismantle process stop simulation
I have modeled a simple a simple situation where a main factory produces some type of MU but it is necessary to send to other factory to make the property operations and then return to the main factory. The problem is when the MUs in containers carried with transporters return and are dismantled the simulation doesn't continue.Why does not take place de dismantle process when the transporter return to the original factory?
Thank you
Re: Problem dismantle process stop simulation
the assembly mode in assembly1 needs to be "attach MUs"
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
